I thought shimming was just the process of getting everything lined up correctly, like shimming a fender to line it up with the rest of the body. If I'm correct that shouldn't make your reaend posi haha. I'll say the same thing as in my other post, DO NOT WELD YOUR GEARS! I know of too many people who've tried it. Let me illustrate . Everytime the tires chirp around a corner it vibrates everything, this will weaken the welds. If one weld fails and finds its way between the ring and pinion, it will lock everthing up. You better hope you're going fast enough that the diff basically explodes and lets you keep rolling, otherwise it'll lock the wheels up, sending you out of control. A mini spool is $80 bucks on jegs. Buy that or have a little patience until a posi rear comes along.
