How does this flywheel look?
6,014
12,729
I'm changing out the clutch on my truck and not sure if I really need to resurface the flywheel. I've replaced clutches before but also replaced the flywheels at the same time, so never had to inspect one. If I absolutely have to, I can get it resurfaced but it would be a lot more convenient if I didn't have to pull the flywheel. How does this one look?
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
10,941
19,992
Socialist NY
Resurface!!!!
Its not a brake rotor where you can just pull a tire off and done.
the trans is out don't cheap out now you will regret it.
Resurface and balance!!!!!!!!!!!
Reactions: 4 users
DRIVEN
8,075
14,536
*CENSORED*
Are those heat fractures at 1 o'clock or did you run over it with something to clean it up?
DRIVEN
8,075
14,536
*CENSORED*
Surface or replace. I know it's an unwanted delay and expense but it's too much work to do twice.
TURNA
Jul 24, 2009
10,941
19,992
Socialist NY
Buy a new one, have it balanced and done.
Nov 4, 2012
6,014
12,729
Ok I'll heed your warnings. I pulled it, I'll drop it off and get it cut.
Thanks guys.
TURNA
Jul 24, 2009
10,941
19,992
Socialist NY
Yep
balance!!!!!
Nov 4, 2012
6,014
12,729
Yep
balance!!!!!
I thought so, I marked it because it looks symmetrical, but apparently one of the holes is actually offset a tiny amount that isn't plainly apparent.
Just checking, better safe than sorry! Thanks again.
