Ok, We installed the new HEI GM performance distributor new wires ( 500 ohms per foot ) Still same persistent stumble .
did vacuum checks and all is steady and stable . Mixture screws set at 1.5 turns out , 12 " vacuum idle about 850 in park.
Timing is right at 13 BTDC. Seems fine when warm at idle. As soon as you start part throttle rpm you can feel the stumble as well as hear it. Driving under load it is more pronounced. As long as your in the throttle in runs good. Back off to part
throttle and stumble occurs. Vacuum advance hooked up or not it still does it. Brand new carb from summit racing replaced 600 EB and the same results. so it's not carb related. It would have sworn it was electrical. Not in the distributor or wires.
Checked hot lead to distributor ign on and get 12.86 volts.
Fuel pump pressure is around 6 psi.
I cannot find any reason for this issue. Brand new GM crate 350 290 h.p
I still think it's electrical in nature but how do I find out what ? Am I missing something maybe at the fuse box or wiring harness level ?
Any suggestions would be of great help here. As I have been with this far to long and running out of options.
jake
jake
