If that's RTV that you applied, to seal the china walls, you're going to want to scrape that off and try again. For two reasons; 1: that's not near enough, you need to apply about a quarter inch thick bead of RTV to make the seal. And 2, you want to do this about 5-10 minutes before installing the intake, otherwise it won't adhere to the intake, too, and will leak.What I applied
Oh no, I already scraped off the china walls gasket and RTV ...the front had the rubber gasket from an intake manifold set, and the back RTV was used to make a gasket.If that's RTV that you applied, to seal the china walls, you're going to want to scrape that off and try again. For two reasons; 1: that's not near enough, you need to apply about a quarter inch thick bead of RTV to make the seal. And 2, you want to do this about 5-10 minutes before installing the intake, otherwise it won't adhere to the intake, too, and will leak.
Hell yea, I'm subscribed to his channel, lot of 305 content 👍🏾I use felpro part number 90314-2, about $20, last I checked.
Here's a decent video of a guy doing the install:
That's almost exactly how I do it, myself. Notice how he also runs the bead up the head just a bit. This helps seal the china wall at the corners. Also, the RTV around the coolant ports helps a lot to hold the gasket in place as you set the intake on, so I highly recommend that.
I use rubber gaskets for my valve covers, a light layer of RTV between the cover and gasket holds them in place, none needed on the head side, usually. If you use cork, I would RTV both sides and check torque on them after a week or two, as the cork will compress and might allow the hardware to back out.
Ok I did it exactly how the video described...intake installed and torque down...❤I use felpro part number 90314-2, about $20, last I checked.
Grey (as mentioned in the video) and Ultra Black...What RTV did you use for the china walls?
