Jeep Shaft Heads Up !!!
So I guess I should get my mig running again. Seems like the easiest and most economical solution
The fix I did above in post # 47 was pretty easy to do,and even though it was welded,I would still recommend drilling and tapping for a bolt.
Guy
Reactions: Longroof79
How much shaft is inside the housing? It'll be easy for me right now since the drivers fender is still off.
this picture answers your question...
img_4368-jpg.93620
Mine has metal arms at the top of the shaft that are flush with the outside edges of the collar. It doesn't look like it could ever come out. I got it from Tim last year. Maybe Jeep improved it on later models. I drilled it and put a bolt through it anyway.
