Here's how much difference I found on bolt-on parts. Yeah, there are better blancers out there, and worse...
The yellow mark was the first one I used (just so I could be IN the ballpark when the game started) and the white one I did once I went down from the bleachers. No fancy store bought tools here. Well... a homemade piston stop tool, a cable splicer's knife and a measuring tape.i'm not just talking as many degrees as thewidth of a paint marker here, it is indeed substantial. I couldn't hear the fan whirring with the first mufflers, the second ones let me hear the MSD box on that side of the engine compartment. View attachment 60721
I'll get a dark line in the next balancer's marker/identifier, and use tin snips to carve a fine point in the timing tab that means zero.
Both were scarred, if that's what you mean. The rod half was flattened out in the middle, like it was being pushed down super hard... which also leads to the detonation problem it had towards the end. R45tsx plugs, .045 gap, accell super stock 8mm wires, brand new HEI dizzy from TA. May have also been the carb air valve doors being a smidge too tight, but that wouldn't cause the erratic idle when the vacuum advance was plugged in or the detonation.
around here, there are "paycheque" parts clerks, and parts pro's... when that right parts person(i can think of a couple o' well versed parts gals in these parts...) is found, you tend to NEED to know their schedules or ya just wasted a trip.(or phone call)the 350 harmonic balancer and a 305 harmonic balancer have a 10° difference for TDC
As stated before, I think the problem was simply repeated 6 grand pulls on a stock (mostly) motor designed to top out at 4200 is a no no. Plus or minus a tuning problem with a hint of detonation also didn't help.
