Re: MEBE007's 80 Regal Build Thread
nice job and I like the stance of your car with those tires....
I see on your tall valve covers you have a breather on one side and the pcv valve opening on the other. I had the same and used the pcv opening to put oil in. I found that that even with the baffle supplied the oil was being sucked into the carb by the vacuum, more so on heavy acceleration. I had to put another baffle there to stop the problem which created the problem of putting oil in the engine. The breather is too hard to get to so I opened up another hole for an oil filler cap. You might not have the problem with the oil being sucked into the carb but if you are using oil you might want to check that out
