Mild 305 cam
It took me a year before I found it, in Canada there isn't the abundance of parts that you have in the US. This 8.2 was the first one I found. I wanted the 8.2 cause it's lighter then the 12 bolt and it's good to around 500 hp
Didn't know you were Canadian. Is it true that Tim Hortons Coffee is the fuel of the nation?
And I meant what year did you find it lol. Cuz if it took you a year to find that rear in like 2003, I can't imagine how long it would take now.
I stay away from Tim Hortons, people actually stand in line to buy the crap, I like real coffee. I found that rear end about 4 years ago...
Reactions: LukeZ
How about group hug? Anyone,anyone? Just me? Sigh...this is awkward. :doh:
Good idea about having the engine on standby for a few years.
And how long ago was it that you found that rear for that price?
Look for a B-Body. Roadmaster,Caprice,Oldsmobile Custom Cruiser. Tall fan shroud indicates tow package. Almost all tow packages have posi...G80 on the id tag. Hope this helps.
  • Informative
Reactions: mr evil
I'm on both sides of the fence with this. From the point that this is a discussion forum, rather than a 'this is how it bloody well ought to be' forum, it helps to hear the good, bad, ugly on both sides. I totally understand Luke feeling he wants to do 'something' to learn and hopefully help his ride out some. However he decides, I hope to hear a positive outcome for him, even if he decides to do something that seems wasteful to some, hopefully it's worth the time/expense to him because he is doing and learning.
Not all 305 heads are bad, most 305s do not suffer flow problems until 6.5k rpms. There are several types of 305 heads, with the TBI swirl port heads having very poor flow and not normally found on carbed 305s used in g bodies. People tend to forget 305s have smaller cylinders which are easier to fill and do not require as much flow as a 350 which has a harder time filling its larger cylinders. It is also why 305s can run more compression than a 350 without spark knocking. There are quite a few LO 350s that do not even make LG4 level power out there such as 70s smoggers and the cheap crate motors that barely make 200 hp, not a good upgrade for the money and effort.
Now one important piece of info Luke left out is the year of his LG4. Early ones had 8.5 cr while later ones were upgraded to 9 cr. Aftermarket carbs are a waste of money for a street cruiser. I agree a roller cam swap/ conversion is overkill on an engine you are not going to keep. Since the op has a overdrive trans, he should go with a 3.73 ratio rear axle with 28 spines out of a later MCSS. Swapping the whole rear axle is easier and cheaper than changing the gears which requires expensive tools.
Clone TIE Pilot,that is an impressive list of upgrades to your motor. Imagine if you had better heads,how much more power you'd have. :lightsab: Said in good fun,Brother...
Reactions: LukeZ
They were done on the cheap, zz4 intake was $20 used, headers were $170 used, both engine and trans were $250 combined. The posi rear was $100. Most expensive part was having the carb rebuilt right, back then I did not know Qjets as much as I do now. The new performance cam was $150. My Regal was originally a base V6, which is a real dog, stuck at 110 hp without rebuilding the entire engine to better specs. My car makes more than double that now, so I am happy.
There are a few of us that just don't like Tim's coffee or most of their food for that matter. The rest block the roads waiting in line. Get 3.42 gears, the smallest shelf grind and it will feel like high and day.
Reactions: L67ss
