Moving the temp sender
You would probably want one 1/16th inch hole in the thermostat.
That being said, can you use the port in the front drivers side corner of the intake? That would be on the correct side of the thermostat. It still wouldn't be as accurate as the head, but in practice it is not a big deal either way.
Yes that's currently the plan...
I recently purchased one for my build and wanted one with a blade connection too, what I had read was that the ones with the blade are for cars with an idiot light instead of a temperature gauge.
Have any of you heard of that, or is that just BS?
I believe at one time that was true. Tried searching for a nonblade type but was told by two different auto parts stores that blade type are all they make now.
Tested two senders. One for a 79 Elky and one i had used in my 76 Chevelle. Neither started out with as high a resistance reading as on the chart but both dropped down to 177 ohms after being heated.
but you need to know the temperature to do the test, in a pot of water on the stove with a thermostat is the way I do it
Reactions: rogus
I went looking last night on Rock Auto & only seen the '78 listing the button, '79-'88 list the blade. Might have to be a Fleabay or Amazon search for old stock units with the button or a used functioning unit.
check the link, you can get the button connection on rock auto. i ordered one the other day
Reactions: rogus
Well, yes, any port with waterflow will work, given the right adapters to fit.
I believe that the highest engine temperature would be found at the flywheel end of the engine, being that is farthest from the water pump. If you can get a sender in the rear most port, it would probably be the best, but up front is easier.
Reactions: rogus
