HELP Need to rebuild my 8.5" boys!
19,992
Return everything you bought so far
Sell the rear as it is for 1200
Go get a 9inch or S60 and never ever have to worry again!!!!
19,992
20,397
he's getting new axles, carrier and c clips so that issue won't be a problem and the op already thought about a 9" in his 1st post of the thread....
"I'm not interested in getting a 9" since I know with the proper parts my 8.5" will be strong enough for what I throw at it. "
81cutlass
4,650
13,572
Western MN
9" is inefficient!!!
Efficiency bro!
19,992
Efficiency bro!
Not if you are producing the torque!!!
Which is why I also recommended the S60
GM rears have always been the weakest of the big 3
To dump a ton of cash into them is just silly IMO
New or old a C-clip is a C-clip.
How many "new" items have we seen fail?????
Just run that rear as is or sell it
piece of mind !!!!!!!!!!!
20,397
C clips don't usually fail, it is usually the axle that breaks at the end between the c clip and end of axle. The op is getting 30 spline upgraded axles so there will be no problem with the axles. On our low end G body circle track cars we welded the side gears with the pinion gears in the 7.5 cause we could not use a posi or spool and we never had a c clip fail, the right side axle would break on the edge of the axle bearing due to the constant stress in the corners and the offset of the wheel
1,167
2,638
West Virginia
Justify all you want. The 9” is king of the street.
20,397
I would get a Winters before a 9".......we used the heavy 9" in our sportsman in our circle track cars but used the Winters in our Pro Late Model. Lighter but stronger than a 9" and you can fit it on any application with bolt on brackets and you don't have to drag around heavy 3rd member is you need to do a gear change.
Injectedcutty
G body LS mafia
Nov 24, 2014
6,057
22,811
Louisville, KY
Next piece to the puzzle showed up today. Now to determine if the diff cover bolts are SAE or metric so I can customize some. Stupid bolts in rearend now don't have markings on the heads, so gonna have to pull one it looks like.
