New engine no start issue
its a start I never run a bottom rad hose with out a spring good luck you are getting closer these thing always take time and patience 2 things I am not good at have a good day Jeff from Winnipeg
Time is something I'm running out of (for this week at least) and patience is something I'm starting to wear thin on, but once I take a step back for a day I think I'll be able to go at it with renewed conviction. For now though, I'm gonna go out and buy the stuff I need to git'er done. Won't necessarily put it all in right now, but I'll have the parts I need at least.
Reactions: Streetbu
Problem is that it doesn't fit on the radiator side because the opening isn't big enough.
Aftermarket radiators typically have larger inlets and outlets than our factory radiators so I usually get an early to mid 70's A-body radiator hoses for a car that has the same dimensional size engine as the one I am installing (BBC, SBC etc.) and cut them to length since they are usually longer.
You used to be able to walk in your local autoparts stores to get these and they did have springs in the lower hoses back then.
