- Jan 25, 2017
- 1,605
- 113
I will try to narrow this list down as best I can. A lot of these parts cross to other years, but this should cut it down to a bare minimum of vehicles to make ordering parts a lot easier. Also note that my engine is a 1 piece rear main seal block. If you have a 2 piece rear main seal block, your flywheel will be different.
2002 S10 - M50 NV3500 5-speed transmission
1998 Chevrolet 1500 - Flywheel (1 piece rear main seal) or
1983 Chevrolet Camaro - Flywheel (2 piece rear main seal)
1998 Chevrolet 1500 - Clutch Set
1998 Chevrolet 1500 - Concentric Slave Cylinder/Throwout Bearing
2002 S10 - Hydraulic Hose (what I used - plastic formed hose on master cylinder end)
2002 Camaro - Hydraulic Hose (what I would recommend using - full length stainless braided hose)
2002 Camaro - Clutch Master Cylinder
Dorman #143557 - Manual Flywheel Bolts
Mr. Gasket #910 - Pressure Plate Bolts
Duralast #2295 - Transmission Mount (2 cross member mount holes)
Duralast #275 - Reverse Sensor Pigtail
Duralast #254 - Speed Sensor Pigtail
SickSpeed Monte - Clutch Pedal Assembly (http://sickspeedmonte.com/Pedal.htm)
G Force - Crossmember and Frame Extentions (TH200-4R Kit)
Optional
Dakota Digital Electronic Cable Drive Speedometer Control Unit - ECD-100-1 (use to drive factory mechanical speedometer with electronic VSS transmission)
Optional
