I don't understand how the engine is cooling if the thermostat is closed? I feel like we must be missing something here. Man, that's a new one on me.
Does your thermostat have one of those engineered holes in the diaphragm that allows water to pass when closed?Yeah, it's jacked up. 35* on the way home from work, drove 45 minutes at sub 155 temps, stopped at schleven, get back in, and it's up to 190 from heat soak. By the time I drove home, about another 10 minutes, it was back down to 155-160ish.
I think I'll book an appointment at the UMD wind tunnel to do some testing......🙄 don't I wish
It's a $43 fah king Motorad from NAPA. When it works, it works great- rock steady. b*tch just don't work in the cold.Does your thermostat have one of those engineered holes in the diaphragm that allows water to pass when closed?
If the 3800 is made with a water pump bypass hose, you can go to a solid diaphragm thermostat to get less loss to the radiator. Although, you could use a restrictor fitting on that hose to help more.It's a $43 fah king Motorad from NAPA. When it works, it works great- rock steady. b*tch just don't work in the cold.
But, yeah, it has a bypass hole with a little loose valve type doohickey in it.
