It is factory style lock column and we haven't looked at the key yet. On our TKO 600 we have the neutral start safety switch wired in.
We really don't know all the technical details yet. Our friend at Flaming River took care of it and sent it. We told him we wanted bulletproof.
ramey
The reason I am asking is that if it is a factory lock as soon as you turn the key back to shut the engine off the steering will lock if you don't have a key release lever. If you are moving and shut off the engine the wheel is locked without the key release lever.
Duh, I just remember your would know that since you had the stock column before. And upon closer inspection there is something under the key that looks like something you'd install something into so it most likely does have the release lever..
