CHRIS.O said:Did they ever take the distributor out when they put the engine in your car? The reason I ask is I do not want to send you on a wild goose chase and have you mess it up and not know how to get it back to normal. So what I am gonna recommend first is you check your firing order just to be sure all the wires are hooked up correctly.
http://www.jegs.com/s/tech-articles/sbc ... ifications
this page has the firing order and some specs.
Find the number one plug and follow the wire going back to the distributor. When you find that terminal on the distributor go clockwise and follow every wire in the firing order to its plug. For example the firing order is 1 8 4 3 6 5 7 2 so when you find 1 go clockwise from there and the next terminal on the distributor should have a wire going from it to the number 8 cylinder in the diagram. Follow that until your back to 1.
Let me know what you find out and if it isnt in the wires being messed up then I will tell ya how to mess with the timing.
Goodluck
Okay I will check first thing when I wake up, I appreciate this all.
Thanks Again.
i will make sure I post on here what I find out.
