Yeah stepping to a chevy 350, from a buick 3.8 . You'll break the back tires loose from a stop if you stomp it, so long as that engines tuned in right.
CHRIS.O said:I am glad to see its coming together bud. All those "problems" are just typical things you deal with when playing with cars. Now that you got a 350 in there your gonna have a smile on your face when you crack the throttle open haha. Gonna be a HUGE upgrade from the worn 3.8.
CamaroAdam73 said:Yeah stepping to a chevy 350, from a buick 3.8 . You'll break the back tires loose from a stop if you stomp it, so long as that engines tuned in right.
SScamino said:Yea, but hopefully you take care of it. It might run good but you don't know what the inside looks like (maybe you do?) Just be easy use a good oil with a high zinc content and save up money for a good rebuild. It doesn't have to wild just a nice stock rebuild and you'll have a motor that you 100% know will last. Not saying that this one won't but you just never know. Be easy with her and she'll treat you right!
CHRIS.O said:Any off the shelf quality oil will work. Just use the conventional oil, with miles on the engine synthetic is a waste and would probably end up causing all sorts of leaks same with Rotella. I use Castrol, Valvoline, Kendall, and Brad Penn. I also use WIX or AC Delco filters. Do you mean your planning on possibly rebuilding the 350 down the road? What do you mean by the rebuild kit will help you with everything? Heres a link about oil
http://www.popularmechanics.com/cars/ho ... ts/1266801
Your engine is old and already broken in so I wouldnt spend a lot of money on a specialty oil with tons of zinc. Valvoline VR1 has a good zinc additive in it and it doesnt cost too much. The amount of zinc in most off the shelf oils is very low to non existant. Zinc is good for lubricating an engine. The main concern now a days is the flattening of cam lobes on flat tappet camshafts. Zinc highly reduces the chance of that happening. However, like I said I do not think you would have any problem running a regular off the shelf oil since your engine has already been broken in years ago and the likely hood of wiping a cam now is slim although it has happened.
CHRIS.O said:Ahh I got ya. Well as far as the stalling, could be a few things. Timing for one, carb adjustment, or possibly ignition wires crossed even poorly adjusted valves but you would probably hear that. My bet would be on timing, especially if the distributor was removed before install and then just set back, could be a tooth off on timing or just need to be tuned in better on the timing. Assuming all else is good. Well sit back and soak the knowledge up from people, your not gonna be rebuilding engines and swapping motors overnight haha, takes a while to learn all this stuff.
