JBreu is right! the solenoid contacts may may burned/pitted. A bad battery connection may also be the problem as mentioned above but thats all I could tell ya. Hoping for the best fellow gbody member :/
CHRIS.O said:Just replace the starter. It eventually isnt going to respond to tapping on it with a hammer. They arent much and do not take long to install.
86 maroon gp 2+2 said:JBreu is right! the solenoid contacts may may burned/pitted. A bad battery connection may also be the problem as mentioned above but thats all I could tell ya. Hoping for the best fellow gbody member :/
RITTER said:Your best bet is to remove the starter and have it tested. That will solve the "starter" situation. You are looking at about $80 for a remanufactured Lifetime Warranty starter for it.![]()
Bonnewagon said:Just a thought. While a solenoid can be had seperatly from the starter, if it's not the problem, can a starter then be had without the solenoid? That is why most places sell the starter with a solenoid, and with a GM it's easiest to replace the whole thing at once. Not to mention that if the solenoid is toast, the starter itself is probably not much better.
David Williamson said:Alrighty final question, how can I get to the starter mine is under the a/c.
I am having problems with taking this out, I am fearful I will have to take out the a/c and then I can get it.
any easier simpler ways to go about on this?
