maddog20_20 said:The jack the car up and the starter will be under neath near the exhaust pipe. MAKE SURE YOU DISCONNECT THE BATTERY before removing the starter or you will see the spark show of your life while getting it out. Please make sure you block the wheels and use jackstands and not just a jack to hold the car up while working underneath. I would hate to here that you got your head squashed by the car falling on you.
X2, the starter is not underneath the AC. It's under the car, pretty much between the engine and transmission. A starter works by spinning the flywheel (flexplate). You will need to either get the car up on jackstands or ramps. Do not forget to disconnect the battery, otherwise you will be in spark city. Aslo, if you can get the inspection cover out it will probably be easier to get the starter out once you unbolt it.
