We’ve probably all had issues with the chrome housing. I have always roughed them up on the bottom and used Permatex Black. I do agree the O ring style are usually a better sealing option. I will use the same method for the dip stick. Luckily I have 2 chrome ones and a steel factory one from the 260 to choose from. Thanks for the input. It’s always appreciated.
As for the fuel pump- yes I’m hoping for a clean install and not having to cut & grind the accessory bracket for a mechanical fuel pump. I have used this pump before with good results. If installed properly with a relay, using a quality pre-filter, I’m hoping for good results. I plan on putting some miles on this car.
Good news... I just got back from looking at storage/shop space, and a deal has been made. I got lucky and the owner was there. After looking at 2 options, I decided on a 14' x 50' with (2) overhead lights, (4) 110v outlets, and (1) 220v outlet = $245 per month, with a 12 month lease. They have a separate outside bathroom facility, and a full size wash bay. Nice! I will move in September 1st.
nice score on the building! I lucked out a couple years ago when the guys at the local scca club offered me a space in their shop. nice to work on your stuff, and not have to pack everything up when you get done...
on the aluminum to steel front: I build truck bodies, and for the aluminum side rail to steel subframe contact, they just use a layer of packing tape in between. they've been doing it for years, and haven't had issues with it.
A couple more parts this week.
I found a NOS Dr. side front bumper filler in a Ebay store for $30 shipped. It must have been stored properly, because it's in excellent condition.
I also bought the Ebay upper control arm set, that some others have bought also. The finish is really nice. I will install them as-is. For new metal, new cross shafts, new bushings, and new ball joints, you just can't go wrong for $67 shipped.
I got a couple other things working for next week. I'm also saving $$ for some paint&body supplies: 60 gallon compressor, DA sander, DuraBlock kit, sand paper, etc.
I'm just 4 weeks away from getting my shop space back. Can't wait!
