We’ve probably all had issues with the chrome housing. I have always roughed them up on the bottom and used Permatex Black. I do agree the O ring style are usually a better sealing option. I will use the same method for the dip stick. Luckily I have 2 chrome ones and a steel factory one from the 260 to choose from. Thanks for the input. It’s always appreciated.
As for the fuel pump- yes I’m hoping for a clean install and not having to cut & grind the accessory bracket for a mechanical fuel pump. I have used this pump before with good results. If installed properly with a relay, using a quality pre-filter, I’m hoping for good results. I plan on putting some miles on this car.
