Sorry Jared, I haven't updated lately as I didn't think I really had anything worth sharing just yet.
I've still been steadily picking away at the "to do" list, but it's been mundane and not overly interesting work that's had to take place. Mostly just a bit of filler work and prep to get things to the point where I can spray some color inside the window channel openings.
I'll give you what I've got so far tho...
Continuing on from the last update, I had added weld to the passenger's side "A" pillar in place of all the lead I had to melt out. It then got ground down and shaped to the contour of the side windshield moulding.
The next step was to repeat the procedure on the driver's side.
Here's the same metal work process completed, but on the driver's side:
With the metal and shaping work now done on both sides, it was time to put the welder and grinders away for a bit and switch to the mixing board and spreaders.
Choosing All Metal for its ease of sanding and strength in the areas I planned to use it, I mixed some up and applied it to the upper corners of each "A" pillar:
After roughly a night and a bit (per side) of block sanding, test fitting, more block sanding and finessing, I had the corners done and the windshield mouldings fitting great.
The passenger's side upper corner after filler work...
...and with the moulding test fit in place.
It should be noted here that the matching of the shape of the opening to the mouldings was done in the metal work stage. The filler is just to smooth out the low spots and finish out the area. None of the filler actually makes up the edges of the corners.
I'm extremely pleased with the end result, it took a considerable amount of time to accomplish, but I think it was more than well worth it.
Just as a reminder of what the fit and finish looked like before, here is the driver's side prior to tear down...
...and now the same side afterwards:
Continued >>>
