Looks like that should do it, if the old brittle tabs were (for the most part) holding then this repair should more than work, you would probably bust the extension before you pulled the tab off
I’m inclined to agree with you.
From the testing I’ve seen and provided my surface prep was adequate, the bond should actually be stronger than the surrounding areas. Being that the surrounding areas are just plastic, it shouldn’t be too hard to achieve that.
Thanks for the input!
I can visualize the finished product, and if it's anything near how I "see" it, that car is going to be stunning!
I’m gonna give Scott a “wink” here.
He’ll know what that means and why because he may or may not have insider information as to what the final paint scheme is going to look like. He also may or may not have had a hand in helping to design said paint scheme with yours truly...
“I can neither confirm nor deny that at this point in time. No further questions, no comment. Thank you.”
Sorry Donovan! I didn't see this until now. I've been on my car a lot more the last month or so and most of the time I spend on here lately has been to keep up with my thread. Awesome work as always. Considering I've seen entire roof skins attached with that panel bonding adhesive, I think your repair will be a very good one, as long as the adhesive sticks to the filler panel and the metal tab. Since I know you followed the tech sheet to the letter and have experience with this particular product, my guess is it is going to stick well.
No worries Jared. I don’t expect everyone to reply all the time to every update I do. When I asked for your guys’ input it was partially as a bump so the post didn’t get lost. Yesterday was quite busy here with lots of activity.
I completely understand, now is your time to really go hard and accomplish as much as you can on your car before it gets too hot there to work on it. I’m also very familiar with the amount of time and dedication it takes to keep a busy build thread up to date. You’re doing a great job on both.
Thanks for taking the time to follow my thread and comment on it. I really appreciate it.
I never hope for things to go wrong, but every time it does, you give us an excellent fix that adds to everyone's overall knowledge base.
Here's hoping to no more issues this year! 😉
Hutch
Thank you Hutch. I’ll drink to that, I’d be quite alright without having any more issues from here on out!
Thanks also for the compliment on my “fix”. When things go sideways ya gotta adapt and overcome or succumb to failure right? I’m just glad this particular fix was pretty easy. It could’ve been a lot worse.
When I saw it broke my mind started thinking about a solution.....mine was almost the same as yours. Great work!
Thank you! Apparently great minds think alike! You got me just a bit curious tho, when you say your solution was “almost” the same as mine, what were you thinking of? I’m always interested in hearing alternatives and different ideas.
I just saw it too and I was going to just vote "simply elegant". None of this "elegance in its simplicity" crap. Completely disagree with that!
Seriously, as long as the bond is good, it ain't goin' nowhere . . .
Thank you Garth. Appreciate the comments.
I trimmed the excess adhesive and attached the bracket tonight. It seems really strong, so I don’t think I’ll have any issues with it.
