Quick parts question
Where would I find the Oxygen sensor and Map sensor on a 86 Monte CL? Mechanic wants to charge me ALOT to do these two things and I already found both parts at half the price he said.
Thank you
Patrick
RebelX
n00b
Jan 5, 2006
South Dakota
i checked my Haynes manual n the MAP sensor is located on the pass fenderwell for carb models or on a mounted bracket for tbi models.
the oxygen sensor is located on the exhaust pipes below the engine. prolly somewhere around the transmission. remember to use anti-seize on it when reinstalling or the next time you may have problems removing it.
hope this helps out.
DrRansom442
858
St Charles Missouri
and don't touch the tip with your fingers, hopefully there wouldn't be a next time on the O2 IMHO I'd pass on any chemicals on the O2 directly
RebelX
n00b
Jan 5, 2006
South Dakota
oops..forgot...on a tbi version its on a mounted bracket on the air cleaner assembly according to the manual.
DrRansom442
858
St Charles Missouri
Re: O2 sensor
lurchsmalibu said:
Don't the threads already come with anti seize already applied?
I don't think so but how many times to you unscrew an o2 sensor?
Jan 9, 2006
El Dorado, Kansas
Re: O2 sensor
HUH?????? HOW ELSE WOULD YOU REMOVE ONE?? oxygen sensor for the exhaust pipe....the ones that I have done rescently for friends have all (new) come with anti sieze on the threads.
Similar threads
G-Body Performance Upgrades
