Rear Axle Identification
Texas82GP
Just-a-worm
Apr 3, 2015
7,917
18,422
Spring, Texas
pontiacgp
blank
Mar 31, 2006
29,270
20,373
Kitchener, Ontario
I have an 8.2 rear in my GP. It's from a 67 Chevelle, the 64 to 67 is 2.5" wider than a G body rear and the 68 to 72 Chevelle is 4.5" wider than the G body rear. I have UMI conversion uppers and UMI lowers with a Roto Joint on the axle side.
pontiacgp
blank
Mar 31, 2006
29,270
20,373
Kitchener, Ontario
Ok thanks
it's not a good picture but you will see it on the crown gear.... you divide the number of teeth on the crown gear (which will be the larger number) by the number of teeth on the pinion.
  • Informative
pontiacgp
blank
Mar 31, 2006
29,270
20,373
Kitchener, Ontario
you may have the RPO code but with a 30 year old car I always like to check cause who knows if the rear end gears were changed, plus I think it's a good idea to change the rear end oil since we don't know how old or what type of oil is in the rear end
Cajun83HO
197
117
Louisiana
My axle tube code is
2 AF O 261
Original 83 H/O. I know it's a 3:73. Trying to tell if this code says it's open or posi. Can't find it on all the charts yet.
