It could be something as simple they sent you a disc/drum proportioning valve by accident and it's keeping pressure applied when it shouldn't be.
Noted.You'll see fluid shoot out if there's pressure on it.
Noted.
Weird noises, yes! Not always, but I have heard a whistle from the proportioning valve. What could this mean?Check the push rod length coming out of the vacuum booster to make sure it is not too long. A longer push rod than needed may be applying some pressure to the rear of the master cylinder piston and applying pressure in the system.
Like said earlier, check to see if the rear calipers are adjusted correctly. The rear calipers should be adjusted by engaging and disengaging the emergency brake, if the emergency brake cables are hooked up and you have a functioning emergency brake system. If it is functional, make sure that the cables are the correct length and not applying pressure when the emergency brakes are not engaged. If the emergency brake cables are too short, it may be keeping the rear calipers engaged and not releasing them fully causing the pads to drag.
If these two things are not your issue, in my opinion, it is either a old rear rubber brake line or a bad master cylinder. An old, rubber line may collapse shut when the master cylinder is pulling fluid back into the master cylinder reservoir. The collapsing rubber line will hold pressure on the caliper and may not fully disengage the pads. The 30 year old rubber lines (2 front and 1 rear) should be replaced regardless if its not the issue.
Master cylinders, even new, do not have the best reputation. I have had customers having sticking calipers and it turned out to be the NEW master cylinder after a replacement master cylinder was swapped in its place. If you are hearing noises from the master cylinder area, it is most likely the master cylinder giving you the issue and a replacement master cylinder should be installed.
Grommet,... which one? Sorry, I didn't assemble it so not sure which you're referencing.tea time....😊
you have a vacuum leak, could be the grommet or the rubber line
And I'll check the rubber lines.
