Rearview mirror with map lights wiring
9,618
12,701
So I bought a pair of rearview mirrors with map lights one has 2 wires the other has a 3 wires, I wired black to ground and blue with white stripe to positive just to see if the lights work, there is also a light gray wire does this go to the courtesy light circuit or does this thing get wired some other way.
Currently just bench testing these.
ELCAM
1,124
1,270
Just a guess, gray is the color for the dash illumination, likely dims (day/night function) the mirror when you turn the lights on.
9,618
12,701
The day/night function is manual
9,194
15,440
Have to ask what donated it. Gray (Cir 157, pin 1) is Interior Lamp Contol, Dark Blue/White (Cir 149, pin 6) is Courtesy Lamp Supply Voltage, Black (Cir 750, pin 8) is Ground. Circuit/pin numbers from info I got for my HHR mirror with map & courtesy lights, temp, auto dim.
9,618
12,701
The three wire was from an HHR I think the other was from maybe a Malibu
9,194
15,440
So you know, it should be the gray tapped into the orange (circuit 40) & dark blue/white tapped into the white (circuit 156). Black I've grounded up near the roof using one of the screw holes for the pre-stamped openning for the power roof switch.
9,618
12,701
old80cs
631
2,073
Massachusetts
Here is the plug on mine
I just put that exact mirror in my '80 Cutlass, however, mine came out of an '07 (?) Impala and had 4 wires into the plug. A Green, Orange, White and Black wires. The green was cut as the pin went to an empty spot on the mirror itself. The others were bench checked and the black wire was ground and the other two were isolated, left side bulb and right side bulb.
