Silverado 5.3 update 12/11
8,826
7,779
Interesting these LS with DOD have these issues, do the newer LT motors? The Hemi's also have cam and lifters failure issues, better now but still occurring occasionally. It will be interesting to see if the 5L Coyote has failures now that is DOD across all lines. There is enough cam phaser issues in Ferd's.
9,176
15,372
disable only, still has AFM parts
lifter #7 got jammed. tore down the top, inspected with flashlight and camera, didn't get twisted and lobe looked ok, knocked the lifter loose with pushrod and hammer, connected computer and Disabled AFM. been running fine for the last 20 months.
That must be lucky #7 cause it seems like that's the one to go. My '08 had the #7 fail & basicly wiped out the engine. The garage that did the swap just had a Avalanche in a few weeks earlier with #7 failure that had to be a complete engine swap.
  • Sad
86LK
1,987
2,052
I'm like the 4th or 5th owner of my truck so I don't know if it happened before. bought it 174k, lifter failure at 185.7k miles
looking at my notes (I keep detailed service notes), I noted that Oil Life from the computer said 5% left after the fix and was having low oil pressure at around 20psi. did an oil change the day after fixing it, drove 3 miles back to the house and had a steady 40psi. idled for 5 minutes after parking and had a steady 30psi
fauxfour2
156
278
I feel like the diablo tuner adjusted the shift points and the throttle response is slightly improved. The big reason i got it was for the DOD deactivation.
One annoying thing I'm dealing with now is a slight oil drip from around the oil filter adapter. Lots of people have said its probably the gasket between the oil cooler line and the oil filter adapter. Anyone else experiencing this?
Again apologies for hijacking this thread lol.
Built6spdMCSS
5,819
9,737
Florida Beach
Yup that's common.
fauxfour2
156
278
Thats what im hearing. The oem gasket was a 6 dollar part and a low level of *ss pain to change or so i hear. Will do it once i complete the Jackson Pollock in oil on my driveway from the drips. Its coming along rather nicely.
