Here is some pictures of the car show.View attachment 91700
In Nebraska, this would get ridiculed: Battery re-location kits are $30. Must be an Iowa thing.
Please throw that knock gauge in the trash and run slightly better fuel than you need. Hell, just put a alcohol injection kit on it.
Three of them are Jamar's Drive-in car show in Fort Dodge. First Friday night of June,July,and August. One was Kamrar car show a few weeks ago. That one was about five miles from my house. Larson Auto body I think does one every month on a Wednesday. Boone used to do one too.where the hell are all these shows at?
There is a lot wrong with that setup if you look close. I think one turbo that size would run better than the two of them. I don't think they will live long with the screen for air cleaners any ways. Cross the river drunken hillbilly! Just kidding.![]()
In Nebraska, this would get ridiculed: Battery re-location kits are $30. Must be an Iowa thing.![]()
That is kind of what I am thinking. I am running 93 with only 10 psi or less of boost with pretty low timing. I would think it would be just fine. My plan is to add a injection system later and turn the boost up. I am trying to get the bugs worked out first.Please throw that knock gauge in the trash and run slightly better fuel than you need. Hell, just put a alcohol injection kit on it.
How much boost were you running? Just curious. I might get some Cam2 and play a little in the fall. I want to keep it together for the Summer at least. No ideas on why my timing is dropping to 0* of the line?I would love those clowns at the track that would run pump gas and when they turned up the boost and got knock, their first response was to turn up the fuel pressure. My first response was to walk over to the race gas trailer and buy 2 gallons of 116 Octane. Unlike the fuel pressure fiddler's, I never blew a head gasket in hundreds of passes. My FP was always 45 psi line off.
That is pretty impressive. Your exhaust made a huge difference. It is on the list for winter, because mine is restrictive and glasspacks on a six cylinder is dumb. How much timing were you running? I am not sure were the timing should be, just going by trial and error.Stock turbo, I was running 18 psi and very high timing chips. Small turbo's like timing + octane. Knock show up on the 2-3 shift and reduced trap mph by 3-5 mph. A couple gallons of race gas and knock completely went away. It was the difference between running 12.99 @ 103 mph with almost a completely stock set up, to running 12.7's @ 107 mph. After ultraflow dual 2.5's, mph went up 4 mph to 110 mph and ET dropped to 12.2's.
You really should read through the thread before commenting or you have tuning experience.What type of upgrades are you planning ? Like maybe some port work .run fuel injection instead of carbs. a custom camshaft. or an intercooler.for some examples
