Mine is a true TH downpipe. I may try heating and bending before I cut it apart. It is off more than the pictures show and the pitch is off. I have a copper gasket. With out the gasket the pitch is better, but still off. Did you not use a gasket on yours?I had the same problem with my Buick for years - spooled like crap. I had a big dollar 3" downpipe so I never figure that to be the problem. Yet, one day I decided to do the grease test and found it wasn't sealing correctly. I planed both mounting surfaces with a fine file to true them up - that achieved nothing. I literally just bent the wastegate puck swing arm toward the turbine housing and this solved the problem.
Careful with any gaskets between the downpipe and turbine housing as that can upset the tolerances.
I would not want to upset you! You definitely need a turbo. Turbo's are so much fun.Don't make me bring the Pig out there!
Glad to see you got it sorted out better.
