I thought the factory jobbies were chrome.
If you're good at rebuilding these things, you can get the pieces parts to do it.
Outer case, that the keyed guts slips into, should you need it, is GM p/n 3064840.
The twisty handle with the tumbler bits is 9632765. Return spring is unobtainum, p/n 3070489. Tumblers , tumbler springs (GM p/n 3901067, strattec 46648), and tumbler retainers (GM p/n 601261) are typical old-school GM junk. O-ring (gasket) shows GM p/n 3065573 or it also could be 3066550, and the rear gasket seems to be unobtanium as well. If anyone has exact dimensions (assuming it's notched), I MAY can cut one on my plotter/cutter thingie I use for decals.
GM p/n 9632765 typically uses a B key slot (key slot requirement stamped on the key). It was superseded by GM p/n 12507441 in the early 90s, so I'm guessing it MIGHT be a different keyslot. Below's a kit on ebay consisting of the handle cylinder and sleeve. The hardest part about these **** GM locks is that the key slot COULD and DID change over the years. So depending on date of manufacture, it will determine which key you need. You don't even want to know how long it took me to get a correct NOS "A" keyed ignition lock. Most are E and C.
3064843 for the pawl.
Kit on ebay is the best way to get tumlbers. GM sold them by the 100 box. WAY too many. You'd have 500 tumblers just to be able to rekey a lock correctly with any tumblers.
Just an option.
