since you're a Moderator here don't you have the authority to take ownership of any transmission owned by a member....something like eminent domain....
I don't know. Let me look into that. Lol.
If I buy a 200-4R it'll be through work. (salvage yard) Most of the time salvage yards will test the engine and transmissions in cars when they inventory the car. Also, most of the yards that I would be buying from give a 90 day warranty. While I have bought used parts from individuals before, I like buying them from a yard. That 90 day warranty isn't as good as a transmission shop but it's a lot better than no warranty from some guy on Craigslist.
I have a stick so I'm safe...
Going for a 200-4R seems like a better option to me, assuming you can get ALL of the parts to do the conversion from a donor car.
What parts will I need? I thought it was a direct swap to a TH350 except for the transmission mount location.
Just off the top of my head (I am sure someone will correct me if I am wrong):
-Trans and converter (duh?)
- detent/TV cable (different length if carb or EFI)
- detent/TV cable bracket (different between carb and EFI)
- floor shifter (differently gated, assuming you have a floor shift)
- TCC plug/wiring harness (can set up using a manual switch).
I believe the TH350 driveshaft and yoke, and crossmember you have now should suffice.
