Ok guys, I’m new here hoping to get an answer that seems to be plaguing us for some time now in a few ways. I will list the current setup below.
- V6 Malibu converted to a sbc 350 and Muncie M20
- truck bellhousing is attached to the engine (#460486)
- 168 - tooth flywheel
- 11” clutch
Current Fitment issues
#1 So far there is a problem with the Clutch fork situation and clearance with the floor pan. We then purchased the clutch fork with the bend however it is not reaching the proper angle inside the bellhousing (picture below)
#2 the transmission hole into the truck bellhousing is oversized vs a car. We have purchased the larger transmission bearing retainer only to find that the holes don’t line up vs the other standard retainer.
I am sure we are not the only ones to encounter this issue. Does anyone have any ideas? Or best practices in doing some thing with what we have to make things work?
Thanks in advance guys! 😀
- 11” clutch
