Been driving the sedan around for the past week and a half or so, running decent, drives well, stops better after a little brake work, lol. Being that I've contracted this strange sickness that doesn't allow me to leave well enough alone, I've been dickin around with trying to get a little more oomph out of the ole bird, keep in mind it already has a 2100 carb, and hei upgrades. I still felt there was more hidden somewhere, I know with my 2.35 gear ratio and over sized tires, she'll never be a ripper, but I can improve on a complete dog, :lol: . My thoughts, hell with it, I'll recurve the distributor for sh*ts and giggles, since I have the springs laying around anyway,
. Here's a little run down for those who do not know what that entails.
Firts step: Remove the cap
Next: Rotor
Now you are ready to remove the springs carefully, may want to use needle nose pliers, unhook the springs and set them aside, you may need them later.
You now are looking at this, while the springs are out, make sure your weights move nice and free with out sticking.
The new springs, one heavy one medium is generally the formula to use.
New ones installed
The verdict:
Definitely an improvement, instead of a lazy wind up, the engine is much more responsive. I had to knock my previous base time back down to 8.5 degrees from the 12 I had it at. Being that the mechanical advance comes in much sooner, it was causing some hellacious spark knock. I still have a little on top to be rid of (high rpm, WOT) I'll have to make a stop to eliminate that. Oh, I almost forgot, rolling at 5mph, if I stuff it to the floor, for a split second, the car "looses traction"
hahaha. I know big whoop right? It's quite the accomplishment considering the little one with 2.73 gears and a 4 speed won't even do that, not without dumping the clutch that is,
