Turn signal problems...need help!
M
Mahlon Entz
19
12
erie
#1
Lights and 4 ways are working on my 79 regal sport coupe but i have no turn signals. I checked my blinker relay and it's good, no power even reaching it after checking with a test light. Any ideas on what the problem is??
Slowpoke
Slowpoke
537
748
I'm sure someone will chime in. An introduction would be nice.
M
Mahlon Entz
19
12
erie
#3
I'm tex. Live up in erie pa.
Just swapped my pick-up for a regal with a transplanted 305. It needs tlc, alot of interior and some body work. It was already gutted for floorpan replacement when i got it. Really excited about turning this into a street beast but as i said before, this electrical issue has me stumped.
Slowpoke
Slowpoke
537
748
Sweet I have a regal as well.. Not sure what your problem is , but there is a ton of knowledgeable people in here.. They will get you right! Hope you stick around.. And a big welcome to the best gbody site .
M
Mahlon Entz
19
12
erie
#5
Thanks man, i really appreciate it! I hope i get some direction in this one!
If i knew how to send a pic i would..
Slowpoke
Slowpoke
537
748
Have you checked the harness going into the column itself? Making sure good contact? Make sure you have the correct bulbs in there too
M
Mahlon Entz
19
12
erie
#7
Have you checked the harness going into the column itself? Making sure good contact? Make sure you have the correct bulbs in there too[/QUOT
I haven't checked the bulbs. I'm assuming they're Right if they work using the 4 ways. It must be a bad connection Somewhere, i was hoping it was something easy and i wouldn't have to tear my dash apart. Whoever swapped the motor left me with a bit of a mess in the wiring dept..lol
Slowpoke
Slowpoke
537
748
You'd be surprised what a wrong bulb will do.. I'm assuming you have checked with a light tester on the harness with outv the bulb?
pagrunt
pagrunt
2,330
1,150
Shelocta, Pa
#9
Check the conector between the tail light & the front to rear harness. There could be corrosion there.
airboatgreg
airboatgreg
974
597
Swap 4 way flasher with turn signal flasher first
Similar threads
