As I stated previously. I already ruled that out..... 5/16 too big and 1/4 too small......Peter said:that pinion bolt is an american size i believe
Didn't think of that. Thank You! I will have to get one today....Peter said:ya 9/32
I'm sure it can be done as you stated. ?? I just would think by doing that you would strip the hex head on the locksrew?? Once you got it out and did your work, did you replace it with a new one then when putting it back together???megaladon6 said:i didn't say beat, i said tap. and to use the SLIGHTLY smaller wrench.
and again, this worked EVERY time. it also worked for ALL of the other mechanics at the shop. matter of fact, it was taught to me by one with 30yrs experience.
the bolts are only threaded at the top, so what often happens is that snapping it, also finishes loosening it. then a pick or screwdriver can get it the rest of the way out.
pontiacgp said:or with the carrier cap off and a small extension or a long socket you can should be able to get a 1/4 drive ratchet in there
