those bolts have a 5/8 head on them, mark the cap so it goes back on as it came off..you just need to remove the one that's in your way and there is no need to torque those bolts when you put it back on, just tighten them up good.
Thats what I was thinking but wasn't sure. I did the outer and chasers on my 91' Bird that was a cake walk, Didn't have to pull the shaft on that Mcpherson style set-up.... If I am pullen the bearings I probably should just replace the stock ones, Timkins.....pontiacgp said:the axle seal is at the end of the tube and the bearing is just behind the seal..to remove the seal using the axle you just use the end of the axle where the c clip goes to pry the seal out
Buy extra for the weeks to come..... Once I get the axle shafts removed and confidence up, drillin' out my backing plate bolts out that twisted off/and will have to be re-tapped will be next on my agenda . That will seem like kids work. Enjoy your Rum, Damnit want another beer but 5:30 A.M. will be here before I know itpontiacgp said:when you get to it I think you'll figure it out pretty easy. It sounds more complicated than it actually is. Plus I'm sitting here sipping on my bicardi black and eggnog so I'm a happy camper and don't want to strangle anyone.. 🙂
I'm not concerned with messing up the threads cause I will get long enough bolts to carry threw, add washer. nut and then backer locking nut...... Hate to brag but I kicked *ss today! Back to my rearend tho>> Not seeing a refill access for gear oil? Am I stupid or blind? Need to replace rear-end gasket obviously sense I gained access to investigate but don't see a fill point at the top to refill "Gear Oil"? Thanks- Mikejrm81bu said:If you really don't want to pull the axles, go to Napa. We have the two-piece backing plates. They are Balkamp number 6411478. There not cheap but they come with new wheel cylinders and some hardware.
