Why are you running a regulator when you have a recirculating style fuel pump? That kind of pump has a built in regulator and sends excess fuel back to the gas tank. That was the factory fix for vapor lock with AC equipped cars. Maybe remove the regulator and see if the problem goes away. FWIW when you have the three port fuel pump and just plug the return port you send all the fuel to the carb. That usually results in a minor flooding condition at idle but otherwise does not affect off-idle or WOT running. That may be a good test to see if you really have vapor lock or something else . When I have a three port pump and suspect insufficient flow to the carb I just take a "T" and plumb the return fuel line right into the supply line. That way all fuel goes to the carb.
