X2mebe007 said:shouldnt matter. the spring is what holds the weight not the spindle
wahoo!1985cutlasssupreme said:i will be buying those beltechs spindles soon.
do you have the 2" drop all around?1979ratrod said:wahoo!1985cutlasssupreme said:i will be buying those beltechs spindles soon.
nope just in the front. i wanted to leave it high in the back give it a muscle car stance kinda1985cutlasssupreme said:do you have the 2" drop all around?1979ratrod said:wahoo!1985cutlasssupreme said:i will be buying those beltechs spindles soon.
if you use drop springs it throws off the camber and it will handle like sh*t and burn up your tires.pontiacgp said:you can just about get the 4 springs for the price of 1 spindle and the spindle is not going to give you better handling
i might get all 4 spindles because i want it lower all the way around.1979ratrod said:if you use drop springs it throws off the camber and it will handle like sh*t and burn up your tires.pontiacgp said:you can just about get the 4 springs for the price of 1 spindle and the spindle is not going to give you better handling
you cant get rear drop spindles. in the back drop springs are the only way to go i think. it doesent mess up anything cuz there isnt anything to mess up back there1985cutlasssupreme said:i might get all 4 spindles because i want it lower all the way around.1979ratrod said:if you use drop springs it throws off the camber and it will handle like sh*t and burn up your tires.pontiacgp said:you can just about get the 4 springs for the price of 1 spindle and the spindle is not going to give you better handling
