do you have pictures of the stance of the car wit the eibachs?pontiacgp said:I had Eibachs, two fronts the coil started to split, took about 2 inched of each coil to remove the split then after about a year that one spring broke and the other side was sagging a bit. I'm changing out to Moog springs for 1/2 the price. I'm going to see if Eibach honors their million mile warranty
the Eibachs did work well and the car's stance was nice with them before the problems
and where can i get those?1979ratrod said:i would really suggest drop spindles over drop springs. they are only like $50 more than springs and you wont mess up your camber. i have beltech drop spindles on my car and they are great. not too hard to install either and it rides great.
1985cutlasssupreme said:do you have pictures of the stance of the car wit the eibachs?pontiacgp said:I had Eibachs, two fronts the coil started to split, took about 2 inched of each coil to remove the split then after about a year that one spring broke and the other side was sagging a bit. I'm changing out to Moog springs for 1/2 the price. I'm going to see if Eibach honors their million mile warranty
