pontiacgp said:that's them, you won't find their spring rates online but if you call Eibach they'll tell you
that is very true im not keeping my stocks im getting racing rims the biggest will probably be 17"regalman4925 said:i threw a pair of spindels on my regal one time, looked awesome but when you drove it since you raised the wheel a inch and a half or 2 inchs, cant remember which, it caused it to be very easy for the wheel to hit the wheel well, had 2 sets of wheels on it to compare also. the springs drop your car, as long as you align it afterwards you should not goof anything up and the wheels can only go up as far as the stock bump stops would allow them to. maybe with stock wheels and stiff springs and shocks you would be ok but my experiance the springs worked better... i dont know many people that keep stock wheels on their g bodies though, most have a wider tire which already will lead to wheel well issues on their own
and also did it change the handling when you put them on?1985cutlasssupreme said:that is very true im not keeping my stocks im getting racing rims the biggest will probably be 17"regalman4925 said:i threw a pair of spindels on my regal one time, looked awesome but when you drove it since you raised the wheel a inch and a half or 2 inchs, cant remember which, it caused it to be very easy for the wheel to hit the wheel well, had 2 sets of wheels on it to compare also. the springs drop your car, as long as you align it afterwards you should not goof anything up and the wheels can only go up as far as the stock bump stops would allow them to. maybe with stock wheels and stiff springs and shocks you would be ok but my experiance the springs worked better... i dont know many people that keep stock wheels on their g bodies though, most have a wider tire which already will lead to wheel well issues on their own
where can i get those moog springs?tobyp said:Moog S-10 v6 Springs dropped an inch or better, the spring rate went way up which increased the handling capability. I have frame to crossmember braces and a rear stabilizer bar, 235/60/15 all the way around. Handles very well. This is an 81.
1985cutlasssupreme said:where can i get those moog springs?tobyp said:Moog S-10 v6 Springs dropped an inch or better, the spring rate went way up which increased the handling capability. I have frame to crossmember braces and a rear stabilizer bar, 235/60/15 all the way around. Handles very well. This is an 81.
