One option is basically the cam that came on
In the ht383, still can find some around guys pulled for a cam with more thump before installing engines and left to sit on shelves. Or buy new here:
Free Shipping - Chevrolet Performance Hydraulic Roller Camshafts with qualifying orders of $99. Shop Camshafts at Summit Racing.
www.summitracing.com
Another choice is find a 96-2000 era vortec suburban, yank the stock roller cam, cam retainer plate and screws, roller lifters, dog bones, spider with bolts. You also need a distributor gear for the shaft dia. of your distributor. Use your tbi heads...you also need the pushrods. You will also need a timing set for the same.
Going used, if in good shape from a junkyard I bet it's about $150-200 investment and you get the whole conversion in one shot. That second option is not going to do a whole lot to change your power and torque curves, but, does give the best bang for buck if the goal is just to get a roller cam setup into the engine and have something with fresh timing set for increased durability....
Either of these setups have the ability/lobe to drive a mechanical fuel pump. Why? Well, again, goes back to some blocks having the boss for a mechanical fuel pump and just aren't drilled for the rod. Other blocks are drilled and have a block off plate. You'll know which you have when you get the engine.
But before installation you could inquire with some local machine shops, see what they would charge to make the pump rod hole functional. Probably costs less than buying the parts for an electric pump...
Of course, you could also go down the project creep rabbit hole, start looking at cam upgrades, head upgrades, all the rest and just baby the flat tappet with zddp while you save up for a more invasive upgrade.
