Started my truck today, then the wife came home and wanted to go out....
put 5 coats of flex seal on leaking windshield. i'll update if it worked.
the flex seal did not work. I used permatex flowable silicone windshield leak repair and it worked like a champ!
I somewhat fixed my starter solenoid wiring and got the car running again. it was a long week since i heard it run lol. still working some kinks out of the electric system tho
Changed out my wiper fluid reservoir.
Before:
After:
Thanks G-Body parts... Nice piece.
Finished up the drivers door handle. It's not perfect but i don't think it looks too bad for it being my first time doing any type of body work.
20140722_172224_zps8yf1siry.jpg~320x480
nice hot day so I drove it hard to see what temp I could get it up to, maxed at 210º so that iss perfect. Tried the Fusion performance tires in the rain and they worked out better than I expected. Here's the current version before it gets covered with matte clear
I worked on a couple projects on my Regal today.
I put in my new TV Cable. I had a universal cable and since it had come loose causing me to burn up a trans, I went w/ a factory crimped cable and custom made a new bracket that located the factory cable the correct distance and geometry to my carb.
I installed my new lower adjustable camber stuts for my IRS( Yes this is in my Regal)...
I mocked up a tow hook for the front of my car that hopefully is not too Ricey or noticable. Reason for this is with my front air dam and front mount oil cooler I have no way to tow my car if it breaks down. I had this issue last fall when I blew up my driveshaft on a hard launch. I had to take my grill out so I could get a strap on it that would not trash my air dam.
I mocked up a tow hook for the front of my car that hopefully is not too Ricey or noticable. Reason for this is with my front air dam and front mount oil cooler I have no way to tow my car if it breaks down. I had this issue last fall when I blew up my driveshaft on a hard launch. I had to take my grill out so I could get a strap on it that would not trash my air down.
Do you have a build thread? Post the link if you do. The IRS has me interested.
