Nice work. While it's fresh in your mind, what type of setup did you use to get on the backups (nuts) inside the frame? I put new mounts on mine while I had the control arms off. I went back with stock replacement mounts (Anchor). I recently saw pagrunt had a bad time with the same mounts. He couldn't get the bolt holes in the upper clamshells to match up with the new lower mounts. He had to break the lower mounts loose, set the engine down, stab the motor mount bolts through the clamshells and lower mounts, and then tighten the lower mounts back to the frame. I'm worried I'll have to do the same.
