I have a clutch pedal too, I find it easier just to do it blind, I stick my left arm up and use my right hand to hold the pedal in place, I find the pin, slide the rod on it and then play with the R clip till it slides into place.
try loosening the 4 booster nuts so you can get some lateral movement of the rod.
The brake light switch is adjustable. It has threads and it will push downward in its metal 'clip' on the pedal support bracket. It will push in but will not pull out. Otherwise, unhook the wiring connector and thread it in.Thanks! I had it partially mounted on the pedal and was having difficulty getting to the booster nuts so I initially tightened them and that made it impossible to move the booster rod over anymore. So in frustration I got out my cordless impact and 2 6” extensions and deep socket. Was able to zip the nuts back off, manipulate the booster and pedal assembly till the rods lined up, got it onto the pedal initially, then gave it a tap with a pry bar and it slid right on. Started the nuts by hand and used the low torque setting on the impact to get them tightened up till I could see the threads from the stud poking out of the nut and sent it home.
Moral of the story, plenty of light, probably 12-18” or extension, hooking the brake pedal first, and patience will help you get a new brake booster installed.
Removing the steering wheel on a non tilt column would probably make things much more convenient as well. Oh well, live and learn.
Today I will be bleeding the brakes and figuring out what to do with the brake light switch since now my brake pedal doesn’t come down the same distance with the new booster... is there an adjustment on the rod out of the booster to correct this?
I noticed that but even bottomed out i don’t think I’m going to have enough. There are two holes on the switch mount, is it possible to use the top?The brake light switch is adjustable. It has threads and it will push downward in its metal 'clip' on the pedal support bracket. It will push in but will not pull out. Otherwise, unhook the wiring connector and thread it in.
Spent about 3 hours trying to get my GBodyparts triple gauge pod to fit.
Heat gun, sanding, shaving not even close.
Went to put the gauges into it just to see what it would look like and they didnt even fit.
No drum sander .........no problem zip tie vise disconnect batt to turn off.
Ghetto sander.........
