What did you do to your G-Body today? [2019]
Reactions: joesregalproject
Adding a cooler is probably a good idea. Today I pulled the one pump out of the Evapo-Rust and put one of the reservoirs in. I'm going to take the pump to work tomorrow so I can press the shaft bushing in tomorrow. The brackets and the pulleys are also in the Evapo-Rust and they are looking really good.
One with and without Evapo-Rust, I am really loving this stuff.
I think Joe's Evapo Rusting the world
Also, don't get the sick bastards in here started with the kink....
Got some stuff done over the weekend, not nearly enough for my liking since Friday night the 18 wheeler dump trailer tire blew out and needed replaced
Spaced out the ac compressor yesterday to make the R4 work with the new water pump and pulleys has a bit too much slap for my taste but seems to work without negative effects or let’s hope so anyway.
I also have to get to those wheel cylinders something is definitely up with the brakes it feels like if I really need to get on the brakes it almost bottoms out the master and the pedal gets fairly hard.
Reactions: TURNA
Another nice day!! Holy cow!!!!
Jumped in took it for a ride down to the OBI (Oak Beach Inn...Long gone)
Look Maa No speedo Needle!!!
Pulled into the parking lot, there were a couple of cars there mostly newer Vettes
BUT........................................ looky what I found.....
Waited around couldnt find the owner, or maybe didnt want to be found............🙁
Came home, took an old cowl seal I had laying around, cut it down to the proper length and BAMMO!!
Instant functioning RAM AIR!!!! 🙄
Well at least it looks like functioning ram air..........
Did you find any dead hooker graves along the Parkway?
8000 miles on these heads started having backfire under heavy throttle... Plus 2 hole where running 200-250° vs others running 550-600°.. machine shop swares the ground the valve and seats
