Aight. Turn that b*tch up from 1 to 2.you'll never learn a new skill if you never try........I would grind those welds and turn the heat up to lay another bead. The welds look cold and I don't see any penetration in the material
Hell, you're there- weld some plates in to box it up!Aight. Turn that b*tch up from 1 to 2.
What welder are you using by chance? The 140 amp Hobart I use was getting real good weld penetration on the recommended setting for 1/8 plate when I was welding on the frame.Aight. Turn that b*tch up from 1 to 2.
Some dumbass ironton northern tool flux core. All I could find short notice.What welder are you using by chance? The 140 amp Hobart I use was getting real good weld penetration on the recommended setting for 1/8 plate when I was welding on the frame.
The one I’ve got sucks so bad it spits in my face 🤣I'm using a 140 Hobart Handler. The recommended settings suck. Run them fukkers hot and worry about warping later 🤣 don't tell Rktpwrd I said that...
Or maybe it knows I’m terrible....
