I had to order new flex lines, the conventional caliper has a larger bango bolt so I ordered the flex lines for a 77 Camaro and they cam in this afternoon. I had tighened the line to to the current flex hose too tight. That was the first time using cunifer brake line and you don't have to crank on it like a metal line. I had to use vice grips to loosen it which reminded me to buy some good quality line wrenches and throw the junk I have in the scrap. I would have liked to chage that fitting but it was a long one and I only had one long one left and didn't know how I'd make out on the other side. I'm lucky I saved it cause the other side would not budge so I cut the line and put a new fitting on. The bracket for the flex line is different on the Camaro so I modified the G body brakets so the Camaro flex lines would work. I plan to change the bracket fit a correct one so I can get the clip installed to hold the flex line in place. When I change the brakets I'll change the messsed up fitting. Neither of the connection leak so that is good. I just did a quick bleed so I can move the car and I'll finish it up tomorrow. These calipers feel better than the low drag calipers I was using...
