Make sure your replacement blinker fluid is non-chlorinated and mineral free or it will corrode the contacts on the bulbs.
I'll disagree with that. Or, the cam isn't right for the compression....Found that a Holley 4150 has gaskets under the float adjusting screws and that the secondaries need to be open a smidge in order for it to even run an engine.
I will note one advantage the Eddy seems to have: I can run the fuel bowls dry.Found that a Holley 4150 has gaskets under the float adjusting screws and that the secondaries need to be open a smidge in order for it to even run an engine.
I also need a center inlet fuel log.
Didn’t have the float level high enough
No, I understood what you meant, I’ve just got this thing messed up more than I thought. It’s leaking from every place that fuel runs, even the float adjusters. It has to go back to the bench no matter how I cut it, though the new fuel cutoffs/adjusters (I know I’m messing up my terminology) from the Trick Kit won’t screw in to the bowls without severe binding. Nothing is cross threaded, but I couldn’t get them to go in more than a turn before they’d just stick in the holes.I'm saying it's unnecessary.
