Gave some thought to Jim Rockford's use of a set of S-10 rims on his more door and decided that a test fit on my Monte might be order. Paid a visit to the wheel racks and retrieved an S-10 alloy wheel c/w tire and tried to mount it onto the rear brake drum/axle. Close, but no cigar. Thought about it some more and decided to try again but with the front hub instead. Still no joy but learned that the it was the shoulder on the rotor that indexes the rim precisely that was the culprit. The matching diameters were close enough but between a minor case of aluminum crud and rotor hub surface rust what I had was an interference fit. "Oh Dremel Tool, where art thou?" A bit of careful attention to both the faces using a couple of micro flap wheels and the result was a nice tight hand-shake fit; 0-0 or about as close as makes no never mind. 1/2 inch drive impact socket on a hand crank and the wheel sat down securely. Can't get at the passenger side right now but think that the game plan for it may be to apply the flap wheel to the rotor hub first and remove all the surface rust that has built up. Get that shoulder to bare metal and then try a first test fit. That might be all that is needed and therefore there being no need for any dremel love having to be applied to the rim itself. Not sure about that as I had to dremel the flange and shoulder on the rear axle on both sides to get the new brake drums to slide on and bottom. The old drums had just that little bit more of an ID and would come and go fairly easily. The new ones do now but like I said, it took some attention to the flanges to get there.
Reactions: MalibuDavyou5
Tried my set of drag wheel tire set-up on my white car
Started it for the first time in nearly 5 years, pulled it out of the garage, let it warm up, backed it back in, put it on jack stands. Then figured out what wheel and tire sizing I could run with the suspension setup how it is, ordered new timing cover kit to fix the oil leak that frustrated me so much that I parked it 5 years ago. Currently browsing wheel and tire pricings, as well as lug nuts.
nuthin
on the other hand
my most viewed video on my channel has over 10k views
in 2005 that'd really mean something
nuthin
on the other hand
I posted that vid in the Oldscool thread. You're welcome.
Reactions: MrSony and Rktpwrd
