Sean and I finished up getting his truck back together yesterday. We got the door back from the painter last Sunday. We hung it on the truck, got the wiring harness fished back in and routed, got the window run channel and window back in it. The window was very slow going up and I found it to be quite unacceptable. We had replaced the motor several years ago and Sean said it was always slow. I didn't remember it that way but he knows the truck better, obviously. We broke off about 5:30 that day and I ordered parts.
Yesterday we started with putting in a new genuine GM outside window sweep/belt line molding. Then we replaced the entire window motor/regulator assembly. Sean put new 3M body molding tape on the Ventshade and got it installed. We had cleaned inside the window run channel as much as possible. After the Ventshade was installed, I wiped down the rest of the channel with some silicon spray on a microfiber. The window goes up and down quickly now. I would say it is like the truck was new.
We also did some heat gun work on the mirror where the triangle base mounts to the door. The top point was sticking out. We would heat the area up, Sean would apply a little pressure to the area, and then I'd cool it with compressed air. It worked great.
The painter just DA'd the area under the spear and then blended in some base. He cleared the entire outside of the door. It still has some small rock chips (under clear now), small door dings, etc. but now the failing clear above the window is fixed and with him just blending the base in the trouble area where the spear was, the door still matches the fender and the rear door. Except for the clear being new, you can't tell there's been paint work on the door. The painter is a collision guy at his day job so a repair like this is his bread and butter. He did a great job.
We're going to let the paint cure for about a month before we put the new spear on.
All better.......
